72 chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2003, 11:39 PM
WV hillbilly
Last journal entry: PTL 220CC
Arrow 72 chevelle
first off, let me say that I feel so stupid telling everyone I have a 71 when in fact my chevelle is a 72!!.... I (today) just received my chevy high performance mag and they had an article on chevelles suspention, I read in there that you can elongate the upper control arms rear bolt holes to adjust the pinion angle...has anyone tried this? I have been having traction problems with it and need to start working on it...I threw on a set of 26x10 McCreary's to no avail...my 60ft times are terrible...2.1 and Im spinning well past the 60ft mark...more like the 1/16 mile!!! other than maybe the modification to adjust the pinion angle what else can I do to the factory 4 link to help traction woe's ? Im not familier with the chevelle stock 4 link set-up and other than tubbing it, I really dont know how I can make it hook, the article helped me understand why, but as far as buying the right parts to fix it, im lost....
Old 07-22-2003, 05:30 PM
the pinion angle can be changed by elongating the upper control, but I dont know that it will help your problem, wheel spin is a traction to track case , try lower air , I hope you have a posi.? the tires you have have the right name but do the have the right code, I think (c) is the soft one , I run mickey Thompson street and strip, no traction problem and they have a DOT # Good Luck. JF
