72 chevelle coil springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2010, 07:41 AM
is there such a thing as having the front springs in upside down?
Old 11-05-2010, 12:02 PM
Yes. The A-body cars have front springs with one open coil and one flattened closed coil. The flattened coil goes up into the frame. The open coil fits into the pocket in the lower control arm. Note that the pocket in the control arm is contoured and the end of the coil only fits in one position.
Old 11-05-2010, 01:51 PM
thank you for you're help
Old 11-06-2010, 11:09 PM
The "A" body lower control arms should have two small holes in the spring pocket. The spring is properly positioned when ONE hole is covered by the bottom coil, but the other is open.
coil vs. leaf springs davetc Suspension - Brakes - Steering 11 11-22-2012 02:17 PM
Sizing Front coil springs JNJo39 Suspension - Brakes - Steering 4 05-09-2006 04:57 AM
weight transfer with front coil springs tony350ss Suspension - Brakes - Steering 1 09-07-2003 01:20 AM
Cut Coil Springs ? zachscc Suspension - Brakes - Steering 18 01-10-2003 08:10 PM
rear coil springs wiseguy50 Suspension - Brakes - Steering 2 10-15-2002 10:18 AM
