72 Chevelle Dash Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2007, 10:06 PM
I am replacing my sweep dash with no a/c out with an ss style dash from a 72 monte with a/c. where do i get my blower switch power from? is there already wires in the harness or do i need to add some from the old harness?
Old 03-08-2007, 11:46 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The existing power feed can be reused on the new blower switch.
The wire should be #14 brown.
vicrod
Old 03-08-2007, 04:57 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I'm Not sure the blower switch needs to be changed..It will operate the same (speedwise and on/off) with or without AC...
Where the changes might come in , is the vent door (if electrical) on the control head for opening and closing the vent doors, and activating the AC Clutch. These CAN be mechanical, (cables) , or Electrical (micro switches) , or Vacuum operated.
IIRC, all the wire for AC should be in the Harness already..but not sure about that..I think they ran them as spares in a Non AC unit so they wouldn't have to discriminate between Non and AC harness on the line..(one fits all) so compare between the two and see.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Original colors of 72 chevelle masterpolisher Introduce Yourself 2 08-13-2006 10:49 AM
72 chevelle ignition switch assembly problems customdrumfinishes Electrical 9 08-10-2006 06:06 PM
72 chevelle 66truck4spd Engine 2 02-01-2005 09:51 PM
'72 to '70 EC Swap. MI2600 Body - Exterior 2 01-16-2005 03:26 PM
will the rear end out of a '65 chevelle fit a '72 Snatch Transmission - Rearend 3 03-02-2003 06:15 PM
