72 chevelle ss dash tach wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2008, 06:04 PM
Hi all
A friend of mine just converted his dash from the stock sweep style to the SS dash with a complete kit with harness and cluster and the tach does not work. power and grounds seem ok, the tach jumps a bit when the key is turned to on position. what I need to know is what color is the tach signal wire and also will this tach(stock GM) work with the tach output from an MSD box.
Thanks
Old 06-02-2008, 08:55 PM
Holder350's Avatar
Auto Parts Professional
If the original cluster didnt have a tach there might not be a tach feed to th
If you have the pos and neg correct the tach should return to 0 when the key is switched on.
you may have to run a tach feed from your MSD box (or the cap on your HEI)
I went thru this same thing on my camaro when I converted to a Z28 cluster.......lots of changing pins in the connector, but only had to run 2 new wires.
Old 06-03-2008, 02:21 PM
You may also require a filter. MSD sells two different ones, and many GM cars with factory tachs used a factory filter in-line on the trigger circuit.
Pat
Old 06-03-2008, 09:53 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
The color of the wire for your tach is a brown one. For more information on this subject go to www.chevelles.com and go to the electrical section. You'll find a lot of info there.
72 Chevelle SS Carb donbutch Engine 4 09-03-2007 01:37 PM
1954 chevy 210 dash wiring skip47 Electrical 4 08-12-2007 09:21 PM
1964 Impala SS Dash 64Joker Interior 3 06-21-2007 12:30 PM
Wiring 4 wire tach cutsupreme Electrical 20 03-15-2007 08:39 PM
71 Nova dash tach wiring connections 1971 Nova Electrical 4 12-22-2006 06:18 PM
