for the year model SBC you have, the timing mark should be at the 2 o`clock position, since there is no mark, go to your local parts store and get a aftermarket chrome timing tab, it should run about $4.00 or so. Next step, install the tab and pop the distributor cap, have a buddy bump the engine over until it`s pointing at the number 1 wire terminal on the distributor cap, then pull the distributor out, then take out the number 1 spark plug which will be the first one on the drivers side, place your thumb over the spark plug hole lightly, and have your buddy bump the engine over until you feel the cylinder pressure against your thumb, find the timing mark on the harmonic balencer, and bump the engine over until the mark lines up with 12 degree`s before top dead center, if you overshoot the mark, you`ll have to do it over again until you can get it there on the compression stroke or the one that your thumb feels cylinder pressure. restab the distributor and again point the rotor at the number 1 spark plug wire terminal, when you drop the distributor, the trick is to get it to fall into the oil pump`s drive shaft, is why you start with the cap off and rotor already pointing at number 1, if it doesn`t fall into the oil pump drive shaft, then use a long screw driver and move it until you can stab the distributor in all the way. tighten the distributor back down, reconnect the cap and power wire, reinstall the spark plug, and fire the engine off.
