Thanks for all the help with this problem.
I used the suggestions of those telling me to cross the main solenoid wire with the post closest to the engine block.
The truck went through all motions of starting, (everything but turn over) but this time, it was almost as if there was no spark hitting the fuel.
In addition, the only way for me to get any activity from the key in the cab is to first cross the posts on the starter. If I don't do this first, there is no activity when I insert key.
Steps:
Open hood, cross 2 largest post on solenoid.
Get inside truck, turn key, truck attempts to start, but doesn't. If I don't cross those post first, I get NO activity when I turn the key.
When I cross the main solenoid post with the post closest to the block, the truck cranks and cranks, and cranks like any truck, but it just doesn't catch.
There was some concern that the motor wa to tigh/seized. The motor was rebuilt about 12,000 miles ago, and when I do engage the post on the starter, I see the pulleys on the motor turning just fine.
Any more help would be great..
Steps:
