72 Chevy Hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2009, 02:46 PM
Mertz's Avatar
72 Chevy Hood
I had a little accident with my truck. 24" of snow fell off the shop and onto my hood and bent in so it has a big crease down the middle. I found a new hood and painted it and finally got it installed. The gaps are ok, not perfect but the passenger side won't drop down all the way to level it with the fender. The drivers side is fine. I removed the rubber stop but that wasn't holding it up. I can push down on it and get it close but it goes back up when I drive. It barely touches the fender when I push it down as far as I can.
Is there an adjustment I can make to get it to lay down right? I tried greasing the hinge but that hasn't helped.
Old 07-24-2009, 03:28 PM
You need to bring the hood latch down.
Old 07-27-2009, 09:50 AM
Mertz's Avatar
I tried moving the latch down and it is a far as it will go. Off course the wiper motor and AC hoses are in the way of getting it off easily.
Old 07-27-2009, 11:24 AM
chevymike's Avatar
Most of the time when the hood doesn't sit correctly and you have exhausted all the adjustments you can, it then tends to be worn out hinges. If you can basically push down the corner having the problem and everything lines up correct but after driving or opening the hood and closing it again, it sit high until you push down, about 100% the hinges have enough play in them from wear.
Replace the hinges, readjust and you should be fine after that.
Old 07-28-2009, 09:57 AM
Mertz's Avatar
I tried shimming the front of the hinge per the recommendations from the thread below (64 Impala) but it didn't work so it looks like its time for a new hinge.
1964 Impala SS Hood Adjustment 64Joker Body - Exterior 4 04-13-2008 10:11 PM
51 chevy hood alignment Area_51 Body - Exterior 2 02-20-2008 08:32 PM
Aligning hood on 54' chevy 210 gavinpierce Hotrodding Basics 6 02-17-2006 10:38 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
Has anybody welded a 2 piece 48 chevy truck hood? tomy2tone01 Body - Exterior 4 04-02-2003 07:48 AM
