Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 72 Chevy pickup, 350 with t-350 is the trans slipping
Old 03-19-2011, 02:04 PM
Mertz's Avatar
Mertz Mertz is offline
I am working on increasing the towing power of my 72 Chevy pickup. I installed new plugs and upped the timing so I am at 36 total. I run my test drive up a 1.5 mile steep grade and it will stay in second until about 55 then when in drive it will barely increase it speed and by the top of the hill I am only doing a little over 60. The temp is ok on the climb but when I get to the top and on the level it goes way up. The truck normally runs cool. At the top of the hill the temp will climb to almost overheated and then it will drop to normal in about 2 miles. Does this sound like the tranny is slipping? The revs going up the hill are at about 3300 in drive. I am in the process of change the trans fluid to synthetic. The fluid I removed (4 quarts) was not clear but not really brown. I will change it again soon with more synthetic.
Acceleration on the flat is great. I can hit 80 very easily. 350 with 350th and 4.10 rear.
