72 Ford Pickup Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2010, 08:11 PM
How do I switch from drum to disk brakes on the front of my 72 ford PU??
Old 07-21-2010, 12:27 AM
Wiki Edits: 31
find a simmilar year truck with discs and swap the knuckle over off the i-beams.. pretty sure you can go all the way to '75. it might require the beams off the donor for some years but I'm not sure which.. you can look at a DJM lowering catalog and find the year groupings for lowering beams to figure it out.. the year groupings will corrospond with stock beams
Old 07-24-2010, 10:10 PM
toomanyoldFords's Avatar
Best way to do it is to find a 1973 to 79 doaner truck. Swap axles radius arms and spindles. You can use the booster ( so I am told) along with master proportioning valve and of course the brakes. I am converting my 68. Dont use the early brake system. It is not very good.
Old 07-25-2010, 11:12 PM
thanks tomanyoldfords, Now to find a donar?
'59 Ford F100 Pickup with Buick engine birdman1 Introduce Yourself 5 11-14-2010 05:23 PM
36 Ford Pickup truck radiator/grill shell assembly Wes Searcy Introduce Yourself 11 10-03-2008 04:08 PM
59 Ford pickup w/ 84 Buick LaSabre 307 birdman1 Engine 6 09-30-2007 12:27 PM
New, with questions! (37 Ford Pickup!) Clayleen Hotrodding Basics 4 04-22-2007 07:41 PM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 06:39 AM
