72 Lemans 350 getting more power - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2012, 02:50 AM
Right now its the stock 350, 7H1 Heads, looking to do a head swap, and along with that i already changed the cam and lifters, timing set, i have headers, holley 4 barrell and so on. Please let me know of any and everything i can do to this motor( i know it isnt a racing engine or anything) but what can i do to it as far as manifold, carburetor, distributor kits, heads, boring or stroking it, transmission work (TH350) and anything else please let me know!
Old 07-03-2012, 08:21 AM
bigblockragtop's Avatar
Boy that would take a book to answer. Maybe give some parameters on where you want to go. Such as money you want to spend, street car, supercharger turbo nitrous race gas, pump gas, e85. That would help everyone help you. I think budget is the most important for me anyway. Then if you make gobs of power will the rest of the drivetrain hold up. Too much power on the street will you get traction. ugh lots of questions to this question.
Old 07-03-2012, 12:59 PM
So what cam did you install? What intake manifold? How "big" are the headers? What Holley?
350 is a decent engine, though not a GREAT one. One cannot make the same level of power as 400 without jumping through a BUNCH of "hoops".
The better 350 heads are the '69 17s and 47s. Even though Pontiac used the 48 ("large valve") head on SOME 350s, it's better to use the small-valve heads. The bore size is so small it impairs intake flow significantly.
Jim
Old 07-17-2012, 03:49 AM
I have the edelbrock performer, a 600 Holley 4 barrel, hedman headers not too big I believe 2 1/2 inch pipes each to a 3 inch collector, its a comp calm I'll dig up the spec card and get that on here as soon as I can, and I'm just going to drive it on the street nothing crazy but enough to get a lot put of it and its gonna be over time so not a huge budget but a mildly modified budget. Which of those heads would you suggest?
Old 07-17-2012, 08:13 AM
Can't tell you a whole lot until I know what cam you're tunning. As for the 17s vs. the 47s, well, flip a coin... A d-port is a d-port is a d-port... Very little difference between ALL d-port heads except valve and chamber size.
Keep compression at or under 9.5:1 for 93 octane gas.
Jim
Old 07-17-2012, 09:35 AM
Banned User
i would look at the differential gear first before anything.
Old 07-17-2012, 10:46 AM
1971BB427's Avatar
[QUOTE=woj's72lemans;1574508] hedman headers not too big I believe 2 1/2 inch pipes each to a 3 inch QUOTE]
Not too big? I'm guessing that's a typo, and you meaant 1.5" pipes into 3" collector. Even the larggest big blocks don't use 2.5" primaries.
Old 07-17-2012, 12:38 PM
Yes that is a typo 1 1/2 to 2 inches and okay thank you .. ill find the cam specs and let you know
Old 07-17-2012, 02:42 PM
I agree with a gear ratio change before any more engine work.
The Following User Says Thank You to FmrStrtracer For This Useful Post:
against all odds (07-17-2012)
Old 07-17-2012, 07:41 PM
Banned User
i agree also. But before a change, let's determine what it is first.
Old 07-18-2012, 02:16 PM
The owner before me put in a 71 non posi rear end how exactly would I find out what it is?
Old 07-18-2012, 02:39 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Jack one wheel, off the ground, put the tranny in nuetral, spin the free wheel two full revolutions, count the number of revolutions of the drive line. Be sure to have a jack stand under the car for safety.
Old 07-18-2012, 09:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A page w/info to help is here.
pontiac, pontiac 350
Pontiac 350 in my '71 Lemans....what to do with it? '71_Slug Engine 8 04-29-2012 11:57 PM
1972 Pontiac lemans 350 exhaust Pont.72lemans Engine 1 03-19-2012 06:11 AM
1972 Pontiac Lemans 350 .. Building up Pont.72lemans Engine 7 10-23-2011 11:03 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
