72 Monte Carlo engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2017, 10:36 AM
Last journal entry: 72 Monte Carlo 350 ci key
sbc 350 put engine together adjusted valves tried to start and timing chain broke. turned by hand OK to adjust valves. It popped 1 time throught carb and just cranked. found dizzy not turning pulled vlv covers and rockers not moving either. found broken chain push rods are not bent and vlv springs all same height. anyone have any suggestion or causes. Put 268h cam and ported and polished 186 heads on.
Old 03-20-2017, 12:16 PM
techinspector1's Avatar
Wiki Edits: 326
I'd be thinking that maybe I dropped a bolt or nut between the chain and sprocket and didn't see it. Keep looking, you'll find the culprit.
Old 03-20-2017, 03:51 PM
hcompton's Avatar
Old & Furious
was this a new double roller chain? They are really strong must have something very wrong for it to snap. Unless it was an old link bar style oem chain that is badly worn. Never seen a brand new chain break. Something is in there that is definitely holding it from turning or it would go around even with crazy heavy spring pressure there i always one spring going down while one is opening so the force is always balanced a bit.
Old 03-20-2017, 04:04 PM
Cars, Trucks, Boats
Was this an old chain? Made in Asia chain? Maybe valve lash adjusted WAY too tight... Good chance a valve or two got bent... need compression tester...
Seen lots of chains so loose they slipped... stripped the gears, etc... never heard of one breaking on a SBC in my 65 years of engines...
Old 03-21-2017, 06:55 AM
Hey Hcompton, It was a Cloyes double Roller and it turned pretty smooth by hand to adjust the valves. I used the 1/4 turn method according to firing order. I can't find the balancer key, but the slot is dead bottom so it could have bounced away when I was pulling the balancer.
Old 03-21-2017, 08:13 AM
55_327's Avatar
Is this your first time adjusting valves? It's very easy to overtighten the rocker arms nuts when there's no oil (i.e. little to no resistance) in the lifters. It's kind of an "acquired touch" in knowing when you're at zero lash.
Also, when #1 piston is at TDC compression stroke, where are the dots on the timing gears?
Old 03-21-2017, 09:05 AM
no I have been doing it for 50 yrs. was just explaining that engine was turning smoothly by hand so I was stumped as why the chain would break when stated for the first time.
Old 03-21-2017, 09:32 AM
55_327's Avatar
OK, got it. Sorry for implying you are a newbie.
Can't begin to imagine how a timing chain could break, especially a Cloyes double roller. Were the distributor and oil pump shaft installed when you turned the engine over by hand? Does the distributor gear look OK? Can you turn the oil pump driveshaft using a large flat blade screwdriver?
Please let us know the autopsy results.
Old 03-21-2017, 10:07 AM
Cars, Trucks, Boats
Have you actually SEEN a 'broken chain'? Or just assuming it's broken because the distributor isn't turning?
Or did the crank sprocket slip because the key fell out of the keyway?
If the chain really did break, please put a picture on here, 150,000+ people here want to see what a broken one looks like...
In any event, as I mentioned, need to check for bent valves... any time crank turns and cam doesn't on most engines...
Old 03-21-2017, 10:38 AM
hcompton's Avatar
Old & Furious
The 1/4 turn method can lead to issues if the lifters are not pumped up first. When oil pumps then up the valves are often held off the seat. I like to watch the plunger to see if it moves. Once there is prelode on the plunger its got enough. No more is needed.
But you can bend all the valves in the motor with small wrench and little effort. Only a dome pistons pushing the valves that are completely out of time could do this. Where the dome is tall enough to try to push the valve close as the cam tries to open the valves. Still dont see the timing chain giving up.
Now the key ways can shear and allow for it to slip. And it can slip like its not even there. Im surprised the cam chain actually broke. There are many weaker parts in the mix that should of gone first. I would love to see a picture. Just love to see carnage sorry...
The only other thing i can think of is the timing chain is actually defective. But this would almost certainly be visible. Like the link broken to begin with.
The only thing that can really break them is running them out of alignment. were the lower gear does not seat all the way onto the crank and causes the chain to bind. this can make them snap when the motor is started.
The miss alignment would be visually obvious. Looking down on the motor the gears would be grossly out of sync by at least a 1/4 inch or so.
Old 03-21-2017, 10:55 AM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
Techinspecter is the only one who has this correct. All this talk about lifter adjustment is a waste of time. And you don't need to be any kind of mechanic to figure this out. If in fact you were able to turn the engine over two three times by hand and then when it starts it breaks the chain no matter how old or how defective, something fell into to the works and stopped the cam gear from turning. Very frankly I'm kind of surprised you're actually asking others for an Analysis. take the damn thing apart which you're going to have to do anyway and let us know what you found
Old 03-21-2017, 11:35 AM
Old 03-21-2017, 12:27 PM
Cars, Trucks, Boats
Yep... it's broken... first one I've seen in 65 years of wrenching on engines... and those things are usually quite strong... does it say USA or China on it? Does it have 4 link bars and 4 link bars? Or is it 3 links and 4 links? I can't quite tell in the picture...
I'm also considering toward something falling into the chain... problems with valve adjustments usually just bend the pushrods... unless it's a weak chain...
Old 03-21-2017, 12:32 PM
Nice response
Old 03-21-2017, 12:57 PM
55_327's Avatar
Any signs that a foreign object got caught between chain and sprocket?
Is the inner crank snout key still in place?
monte carlo engine montecarlogb Engine 1 05-08-2006 08:08 PM
monte carlo engine montecarlogb Introduce Yourself 1 05-08-2006 07:53 PM
Monte Carlo Engine Swap Dans83Olds Engine 4 10-16-2003 12:24 PM
Monte Carlo Engine Swap question Dans83Olds Engine 4 10-07-2003 09:45 AM
Monte Carlo 350 engine Seon Engine 5 12-01-2002 07:28 PM
