Thread Tools Search this Thread share on Facebook
  #1
Old 10-04-2011, 01:26 PM
72MGC 72MGC is offline
72 Mustang Neutral Safty Switch
Im trying to get the 351W finally turned over. I did not remove the old trans but have installed the C6 myself. So im a little clueless with stuff and learning. Im going from C4 to C6 from a truck which was column shift. It looks like I will need a new kickdown link. And also using the old shifter link from the car, when the trans is in park the shifter reads 1st, its opposite. Assuming I am correct with the shift pattern being front to back from the lever in the trans. Anyway, there is no neutral safty switch on the trans. There are some wires coming from the shifter but lead to nothing, im thinking those are backup lights. The car is completely dead, im thinking I need to properly bypass the NSS from the firewall. How to do this? Shed me some light! Thank You
Register now (free) or login to remove ads
Old 10-04-2011, 03:09 PM
35terraplane's Avatar
35terraplane 35terraplane is online now
Nss
I'm not sure how it's wired, but I'm sure you don't want to by-pass the NSS it is big trouble if you hit it in gear. Hook it up right, and be safe, you sure don't want the car going through the end of your shop.
Bob
Old 10-04-2011, 03:19 PM
I understand, if I dont sell the car it will be done right! This car is for sale and im only looking to fire the engine asap for a possible buyer. He will be aware of this. I think I just need to connect the two wires for the NSS but not sure.....
Old 10-04-2011, 03:45 PM
Nss
That's all you need to do is by pass SW.
Bob
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "72 Mustang Neutral Safty Switch"
ThreadThread StarterForumRepliesLast Post
2004 Mustang Park/Neutral Switch2004MOPARCROSSFIREElectrical201-14-2011 09:17 AM
neutral switch?3gencamaroElectrical303-15-2010 05:53 PM
I cant shift! Is it the neutral safty switch???elcaminodragsterElectrical602-25-2009 07:13 PM
nuetral safty switch on 86 mustang85stangboyTransmission - Rearend1812-20-2004 06:38 PM
neutral safty switcharmaliteElectrical502-06-2004 12:37 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
