#1
72 Mustang Wont Turn Over
Im trying to get the engine to turn over and it is completely dead. There is a black/orange wire leading to the solenoid area that has been cut. I do not know if this is the reason or not. The negative side of the solenoid only has a cable leading to the starter. The positive side has the battery cable and two other small wires, one is yellow and the other I think is green, leading into more wire mess. There are two red wires leading to the solenoid also in the middle. I do not know if this is correct, can someone please shed some light. Or know where a good diagram is free? Thanks
Register now (free) or login to remove ads |
#2
Ive read elsewhere that if the two smaller wires on the solenoid are reversed it will be dead. Is this true? I will check this later ofcourse... At library now, looking to get as much info as possible.. Thanks
#4
#6
There is no negative side of the solenoid. There is the battery side and the starter side. When the solenoid engages it connects the two. One of the small wires on the solenoid is used to engage it the other is usually a secondary ignition feed to feed power to the ignition while cranking.
If the 2 small wires were reversed the engine will not crank. You can test the solenoid by jumping from the battery side large post to the small s terminal, this should cause the starter to engage. If it does then you have a wiring issue, could be the ignition switch, a broken wire neutral safety switch etc
Artificial Intelligence is no match for Natural Stupidity Chet |
#7
Thank you! I fixed some wiring that I had done wrong according to the diagram. It still would not do anything, dead silence. I tried your advice on testing the solenoid with a battery charger and the starter did not engage. I then removed the starter and tested that itself..nothing.
The starter must be the problem. Although I would think I could hear some clicking or something from the solenoid. Its completely dead. I will replace starter and go from there. |
| Thread Tools | Search this Thread |
| Similar Threads for: "72 Mustang Wont Turn Over" | ||||
| It wont turn over | mrbankston86 | Introduce Yourself | 1 | 07-22-2010 06:44 PM |
| It wont turn over | mrbankston86 | Electrical | 1 | 07-21-2010 03:15 PM |
| Just Wont Turn | willyb1 | Suspension - Brakes - Steering | 0 | 05-11-2010 06:25 PM |
| wont even turn over | bigpimp2988 | Electrical | 9 | 05-12-2004 04:26 AM |
| wont turn over | 53LEDSLED | Engine | 3 | 04-14-2004 02:27 PM |
