72 Nova 12" wheels ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 08:34 PM
Last journal entry: In the beginning
I'm having a problem getting some answers on how to measure, and how much to narrow my 8.5/10-bolt posi. I'm in the process of mini tubbing the wells, and I'd like to have the rear done so its ready to install when I wrap up this job.I'm using the DSE mini's (+2 1/2")and the leaf springs and shocks are gone---coil-overs and ladder bars. I'd like to go with 12" wheels.
Any help ??
Thanks, street
Old 04-19-2006, 08:41 PM
Crosley's Avatar
Wiki Edits: 1659
Any help ??
Thanks, street
to avoid a problem , buy the wheels first , then measure
Old 04-20-2006, 06:13 AM
STUPID is as STUPID does...
Ditto! You HAVE to have the tires and wheels on hand to get accurate measurements. Once you get the tubs intalled set the tires & wheels in place, where you want them, and then measure the distance between the mounting faces. Just remember this measurement is a TOTAL distance, over the brake drums or rotors and the "housing" width will be shorter.
Here is a work sheet from Chris Alston's site. It will get you pointed in the right direction.
http://www.cachassisworks.com/worksh...structions.pdf
Mark
Old 04-20-2006, 06:51 AM
tnsmith10's Avatar
when will it rain???
12" wheels? the car origionally came with 14" wheels. please tell me that ur not going to ruin this car with those cheesy spoked lowrider wheels with tires that dont fit right...
ahhhh, scratch that last remark... i saw posi in there... drag car? best of luck man.
Old 04-20-2006, 08:23 AM
Originally Posted by tnsmith10
[I]12" wheels?[/I] the car origionally came with 14" wheels. please tell me that ur not going to ruin this car with those cheesy spoked lowrider wheels with tires that dont fit right...
I understood him to mean 12" WIDE... Not 12" in diameter...
Mark
72 camaro subframe in my 72 nova 396nova Suspension - Brakes - Steering 4 07-09-2011 04:58 AM
72 Nova Body Work leejoy Body - Exterior 3 12-26-2005 06:48 PM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 09:24 PM
Wheels on my Nova Novaman78 Hotrodders' Lounge 9 11-07-2003 01:19 AM
72 Nova Seats novachad Interior 2 01-22-2003 08:20 AM
