72 Nova Control Arm Bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2011, 10:25 PM
In the midst of doing a drum to disc brake conversion and decided I may as well R and R all of the front suspension ball joints, tie rod ends and the control arm bushings ( mainly the upper arm) I figure I maybe able to utilize the "clamp and big socket/ little socket method" (poor mans press) on the lower control arm. I am lacking in a bench press for such a task in relation of the upper control arms. Anyone have any creative ideas to accomplish this? Or am I just stuck at farming out the installation of the CA bushings after my "parts kit" arrives?
Old 01-10-2011, 11:47 PM
how do you post pictures on here? I have a picture of how i pressed my lower bushings with some home made tools that cost a total of $7 bucks...
Old 01-11-2011, 08:42 AM
1971BB427's Avatar
If you do much car work, you might consider buying an inexpensive press. I found one at the local Harbor Freight for $100. It's rated 10 ton and is big enough to do anything I ever needed to do. Over the years it's saved me more than it cost for sure.
Old 01-11-2011, 08:52 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i also have a HF bottle jack press, it works ok and will get the job done most of the time
Old 01-11-2011, 01:43 PM
I've had good luck burning the rubber out with a propane or oxy-cetylene torch (do it outdoors over a metal bucket!) then crushing the metal sleeves with a hammer and chisel for removal. A less messy method is to use a roto-zip tool to cut the rubber out then crush the metal sleeve.
Old 01-11-2011, 02:06 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Verify if the new bushing have sleeves, sometimes you have to reuse the originals.
Old 01-11-2011, 03:24 PM
In this case, new factory-style bushings come with sleeves.
control arm bushings Ajkracing Suspension - Brakes - Steering 8 09-29-2010 07:18 PM
control arm bushings montea Suspension - Brakes - Steering 15 04-22-2007 07:06 PM
control arm bushings chevypunk Suspension - Brakes - Steering 5 10-30-2003 09:21 PM
Control Arm Bushings 69 chevelle SS Suspension - Brakes - Steering 1 08-10-2003 07:50 PM
78 nova control arm bushings brad_irc Suspension - Brakes - Steering 1 07-20-2003 08:08 PM
