72 nova ladder bars - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 05:04 PM
Last journal entry: In the beginning
72 nova ladder bars
Im looking for any suggestions from anyone having any experience with this situation, with any car. I'm installing a coil-over/ladder bar suspension in a nova. Relative to installing the ladder bar cross member, and mounting the ladder bars with the included heim joint and through bolts--- I'm concerned that this setup is going to create a real harsh ride. I know this solid connection is the positive aspect of this installation, but I'm building a streetrod not a drag car.I thought I might mount this connection through a rubber bushing just like the original leaf springs are mounted.
Any thoughts...
thanks, t-bone
Old 09-26-2006, 09:10 PM
larryblack's Avatar
Certified Lead Foot
I drove a 68 camaro with the same basic setup you described. You cannot take tight turns into or out of driveways. It really is not to bad of a ride. Forget about quick lane changes. You cannot try and be a TFTF type driver.
I also recommend you DO NOT load the trunk or carry back seat passengers.
Since you are NOT building a drag car IMO you need to loose the idea of a ladder bar suspension. It will not last as a daily driver. Now if you are building a trailer queen show car, have at it.
Old 09-27-2006, 05:35 AM
astroracer's Avatar
Ditto! Ladder bar suspensions are a drag race suspension like Larry said. You will not be happy with it in your "streetrod". Especially if you want to drive it. I would recommend simply rebuilding the leaf spring suspension, get some good shocks and drive it. Much simpler and much less prone to failure...
Mark
ladder bars in my chevelle dk01_99 Suspension - Brakes - Steering 15 04-08-2013 07:24 PM
Best darn ladder you will ever use. MARTINSR Off-Topic 11 03-31-2006 08:21 PM
Ladder Bars fred56 Suspension - Brakes - Steering 4 08-06-2005 10:53 AM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
parallel leafs, or ladder bars & coil-overs? sandman351 Suspension - Brakes - Steering 1 08-28-2004 08:33 AM
