72 Nova Leaf Springs Question - Help!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2006, 09:38 AM
72NOVA454
Help
I just picked up "new" 5-leaf multi-leaf springs from a discount parts supplier locally here in chicago area. they are for my 72 Nova. The new springs are the correct size, width, etc. However, they are lighter in weight and seem "softer" than the old springs I took off the car. when I say "softer" I mean when stand on the spring and bounce on it with my body weight - it seems softer and the deflection is greater than that of the older 1972 spring. Is that ok or not? I am bothered by this whole thing. The parts store says it is the correct part and they have been using this spring for both F body and X body cars for years. This is my first leaf spring replacement and I have no experience doing this before. Please help. I don't want to do this whole job twice. Do you think the new springs are ok?
Your thoughts please.
Lee
Old 11-04-2006, 10:55 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Comparing the spring rates of the old and the new assumes the old ones are correct. Becareful there.
Is there any circle track shop in your area who can rate them for you?
Old 11-04-2006, 11:23 AM
72NOVA454
I appreciate your response about comparing old to new - but I am 99% sure the "old" leaf springs are the original ones from 1972. I've only had the car a few years but the spring look old, and the nuts and bolts to remove them were definitely very old and rusted. why would the "older" springs be "stiffer" than the newer springs. doesnt that seem odd to you?
and no about the circle track thing. I am in chicago area. nobody around here even knows what that is.
Lee
Old 11-04-2006, 11:56 AM
It seems odd sure enough. I don't know if that a good guess or not.
The basic perameters of spring rate on leafs are"
http://www.thedirtforum.com/leafspringrate.htm
If your old ones are close, I'd use em.
Old 11-04-2006, 07:21 PM
72NOVA454
I just measure the "stack" of old leaf springs (5 leafs) vs the stack of the new leaf springs. sure enough, the new leaf springs are 1-1/4" thick and the old ones are 1-1/2" thick. that's a big difference - explaining why they are lighter and softer. I am returning them. I don't want my nova to sit lower once the car is on the ground and I am not taking any chances.
Lee
72 Nova tubbs 5bigdoghouse Introduce Yourself 2 10-21-2006 07:32 AM
rear leaf springs HD chopped pickup Transmission - Rearend 2 11-05-2005 01:31 PM
72 nova bucket seats question ?? fnoblitt Interior 5 01-16-2003 05:55 PM
leaf springs ffcagle34 Suspension - Brakes - Steering 4 12-18-2002 06:49 PM
rear end/ leaf spring question chris1950 Transmission - Rearend 5 07-30-2002 10:19 AM
