72 olds pulls after rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 11:00 AM
Dano1972's Avatar
New Member
I need some help with my 72 olds. I have recently rebuit the front suspension with a new polygraphite kit from PST. I took the car for a spin around the block and noticed it pulls to the left any speed pretty bad. It's a 30 mile drive to the shop where I plan to have it aligned. I really wanted to try and make some adjustments myself so the trip to the shop won't be so dangerous. I have plenty of time to tinker with it. Any help would be great. Thanks Guys.
Old 05-07-2005, 01:59 PM
Toe is what will wear the tires in a hurry. It is also very easy to get it close with just a tape measure. I would just set the toe and drive it to have the alignment done.
Old 05-07-2005, 07:36 PM
it's either hotrod.com or carcraft.com that has a good article in their archieves about doing an at home alignment. it will get you pretty close with not much more than a tape measure , level and a 2x4. i did this with my 72 chevelle and it worked well.
Old 05-08-2005, 03:45 PM
Dano1972's Avatar
New Member
Thanks guys. I checked the articles then my car and found it to be almost 3/4 inch toe out! Got it to 1/8 inch tow in and it drives much nicer. Nice enough to get me to the shop.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
72 chevy rebuild HalfCutSkeleton Engine 3 01-22-2005 10:23 AM
72 Olds Cutlass - Stick no dipstick! Sparksfarm1 Engine 10 09-07-2004 06:43 AM
72 olds cutlass questions Sparksfarm1 Engine 3 08-27-2004 12:17 PM
Olds Rocket 303 Rebuild Suppliers??? taildrager47 Engine 1 08-27-2002 10:50 AM
