Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 72 skylark coupe, worth it
Old 11-18-2012, 12:26 PM
TexasT's Avatar
TexasT TexasT is offline
Did you ever wonder?
Last journal entry: A little follow up
Just to entice you a little more, that car is likely equipped with a 8.5 in 10 bolt corporate rear axle with bolt in axles. Very strong(not 9 in ford but strong none the less).
With a 2004r swapped in place of the th350 I would bet on low 20 mpg numbers. Very reliable,safe transportation.
