727-b no 2-3 upshift,no 3rd - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2009, 01:31 PM
ratlover's Avatar
Hi guys,
been a while since my last post. I am working on a 68 GTX with a 73 727 trans behind a 440. I Recently took the car on it's maiden voyage only to discover I have no 3rd. i have a lokar kickdown linkage to the pressure control valve and have adjusted it as per spec, even disconnected it to process the variables affecting this condition. It has a b and m transpak shift kit where two balls in the #1 and 2 position were removed and the valve body drilled as per instructions. I rebuilt the trans with all new bands and clutches, seals etc. (king master kit) and setup band adjustment according to spec. The rear clutch clearance was set to.020" front clutch .090". fluid level is fine, have even tried over adding a liter. Removed govenor and cleaned and reassembled seems to be free, 1-2 upshifts automatically crisp and on time at about 25-30 mph. Have driven in D up to 60 mph and pedaled the throttle to no avail still no third. There was no third prior to rebuild either. the shift kit was installed prior to road testing the car. any suggestions? Thanks.
Old 06-21-2009, 05:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Does the car back up with a solid reverse ?
Since this problem was there before the parts replacement , I would guess you missed the problem.
First guess would be a stuck shift valve.
I do not use B&M shift improver kits, you may re-visit the instructions while checking the valve body over.
Does the clutch packs air check correctly?
Is it possible you broke a sealing ring on the front servo in the case? Or did not remove it during the parts replacement?
.020 on the input FWD clutch is OK... this is the drum with the input shaft.
.090 is a bit large for the direct clutch pak ... this is the drum the front band applies on.
Old 06-21-2009, 07:23 PM
ratlover's Avatar
I think i figured it out. you were right by the way... I re-checked the transpack instructions and pulled the valve body. I had removed balls #1 and 2 in the valve body. (thats the 11/32 and 1/4" checks). The #1 and 2 balls in the seperator were the only ones to be removed. The way it was written led me to believe that was the correct thing at the time I guess. I have not tested it yet but I put the checks back in. I'll keep you posted. here's the manual for those who are interested.
Turbo 350 dropping out of 3rd gear aoz28 Transmission - Rearend 1 06-18-2008 08:45 PM
delay going from 2nd to 3rd gear aafc Transmission - Rearend 3 12-17-2007 07:54 PM
700r4 skipping 3rd gear? tylordurben Transmission - Rearend 46 10-24-2007 07:03 AM
700R4 3rd & 4th lockup chrisape Transmission - Rearend 6 11-14-2006 06:25 AM
727 slips from 2nd to 3rd gorf24 Transmission - Rearend 4 08-20-2005 07:00 PM
