Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A-727 doesn't go reverse
Old 03-17-2013, 03:28 PM
cu42 cu42 is offline
I bought a 1978 Chrysler Lebaron knowing it developed a problem with the transmission, it doesn't move backward. If selector is in "R" and you press the gas pedal the engine rpm goes up but doesn't move the car. "1" "2" or "D" car move forward ok, in "N" you can feel car try to move forward a little bit. When I received the car the fluid level was higher than normal but I do not think this could be a reason for this problem.. I'll really appreciate your comments on this.
