A-727 doesn't go reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 03:28 PM
I bought a 1978 Chrysler Lebaron knowing it developed a problem with the transmission, it doesn't move backward. If selector is in "R" and you press the gas pedal the engine rpm goes up but doesn't move the car. "1" "2" or "D" car move forward ok, in "N" you can feel car try to move forward a little bit. When I received the car the fluid level was higher than normal but I do not think this could be a reason for this problem.. I'll really appreciate your comments on this.
Old 03-17-2013, 05:43 PM
33Willys77's Avatar
You would have to pull the pan and see whats in there. Could have broken the band or the band servo could have popped out (rare). You will need a rebuild.
Old 03-17-2013, 05:53 PM
727
The 727 has a reverse band adjustment. Drop the pan and see if there is some room to tighten the band up. If it is fully tightened then a rebuild is your only option. Bands can be replaced...but have the whole trans gone through as there is probably debri throughout.
Old 03-17-2013, 08:23 PM
Thank you guys for your reply, I will drop the pan and check the band adjustment.
mopar 727 tranny lost reverse probable causes how to fix? mypowerwagon Transmission - Rearend 2 12-28-2010 09:29 PM
727 reverse band problems racerrob Transmission - Rearend 2 04-12-2010 07:43 AM
anyone know how to make a reverse shift pattern 727 valve body? the nitro man Transmission - Rearend 0 06-13-2009 11:18 AM
94 Dodge pickup reverse doesn't work grapro Transmission - Rearend 2 08-10-2007 06:53 AM
727 reverse shift/tremor problems Gen3_with_455 Transmission - Rearend 1 11-09-2003 12:47 AM
