Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $4,333.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-08-2004, 02:21 PM
nettio's Avatar
nettio nettio is offline
727 help please
have 327 with 727 transmission. Very tight fit in car and control cables and or rod not installed, and no space between engine and firewall to install. upon accelleration the trans drops out of low immediately and skips second.
Believe I can run a cable thru the passenger compartment to tranny but will admit I have no idea how this operates.
Thanks for any and all assistance............
Al
Old 02-08-2004, 05:27 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Streetbeasts lawsuit donor
M&M CUSTOM's barnstar
Wiki editor
Last wiki edit: Rust
Wiki Edits: 7
Re: 727 help please
Al
I am only assuming you are talking about a Chevy 327 with an adapted Chrysler Torqueflite 727 transmission.
Is there enough room from the transmission shift shaft to fit a socket on to remove the shifter bracket?
If so, you should be able to use almost any aftermarket shifter that is cable operated.
If you prefer not to use an aftermarket floor shifter, the same concept can be adapted over to use the column shifter if vehicle is equipped.
With a cable operated shifter the shifter mechanism can be mounted anywhere necessary, or unusual such as in the dash, as long as there is no binding in the cable.
Old 02-08-2004, 06:16 PM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
327 AMC?
You will need to somehow figure a way to put the rod in place, you need it.
Old 02-08-2004, 08:16 PM
slowturbo slowturbo is offline
THe lack of a kickdown/throttle valve linkage that is causing the early shift you are describing, as those linkagees control shift points and firmness at ALL throttle positions.
You pretty much have two choices - Either find a way to hook up the linkage, or switch to a full manual valve body, which will eliminate the need for the linkage but you will have to make all shifts yourself.
Old 02-08-2004, 09:55 PM
Crazy Mopar Guy's Avatar
Crazy Mopar Guy Crazy Mopar Guy is offline
The kickdown determines shift point, it controls the mainline pressure. On some year 727 transmissions it also affects the kickdown point.
The kickdown HAS to be hooked up with an automatic shifting valve body.
No kickdown hooked up will not only do EXACTLY what you describe, it will destroy your transmission with time.
Lokar, among others, make a cable kickdown kit that fits just about anywhere. Easy to install too.
Old 02-09-2004, 08:57 AM
nettio's Avatar
Thanks to you all
Thanks for the info.
I was not entirely clear about the installation.
The car has a hurst shifter...but no contgrol rod from the carb to the trans.
The installation is so tight that it is impossible to get a control rod under the floorboard and up around the bell housing.
however, I think it is possible to run a nylon tube up thru the floorboard, alonth the driveshaft tunnel and out thru the firewall to the carb.
Question............does it have to be a rod, or can I use a cable.
Thanks again......Al
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
