I'd like to use my 66 Chargers 727 in my Model A Tudor. It has this crazy long tail shaft...19.5" from its mounting point with the main case to rear output shaft. Overall the trani is like 37". Is it possible to swap on a shorter tail shaft? Are they interchangeable...whats involved in swapping?
If I kept this long stinger the drive shaft will only be 3 feet long.
Thanks,
Dave
You can use a motor home/van tail housing which is 12" long, or a truck tail housing which is 8" long. Both of them require a 2 piece driveshaft as both use fixed yokes as opposed to slip yokes.
You need to swap everything on the back of the transmission, but you need to partially disassemble the transmission to change the output shaft.
That's kind of a bummer...are all the car 727's running that long tail shaft housing? I have a drive shaft with a slip yoke ready to go...just needs shortening....
I'm leaning that way at this point too. I'll note the amount of u-joint angle with the longer shaft (shorter drive shaft) and see if its severe.
I'm looking at the sportsman rebuild kit from SMR Trams...any comments about these guys products?
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
