727 reverse band problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2010, 11:08 PM
hello i am looking for some help diagnosing a problem with my 727 transmission in my 68 charger. I rebuilt this transmission last winter and it is mostly stock with the exception of b&m shift kit and a billet reverse servo piston with solid bushing and heavy duty return spring. I am running type f trans fluid. the transmission seemed to work fine for about 50 miles with the exception of when shifting from manual low to second at low speed there was a lot of hesitation but it would shift fine in drive or when i was getting on it. then when driving down the highway one day in drive at 60 mph it seemed that the transmission was locking up then it released later that day after backing out of drive way and starting down road when it made 1-2 shift the transmission locked again then broke loose 1-2-3 all worked but no reverse the sprag was holding in forward gears but it broke the stock servo piston and the band was very loose replaced servo and adjusted band and tried it again today. worked great for a while then on way home it started to act like the reverse band was applying in high gear again so i parked it reverse still works but i really need help figuring this out before the band is shot or worse any ideas would be greatly appreciated
Old 04-12-2010, 07:21 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the band adjustment is correct, I suspect a crosss leak if the valve body sections were not flat sanded to level them.
I adjust the band by visual , rather than turns on the strut. I like just under 3/8 inch gap as i pry up the band arm with a good sized screw driver.
Next , drill a relief hole of .045 - .055 diameter in the valve body casting right at the hole in the case that feeds the rear band.
This hole does a couple of things: Mopars tend to build very high pressure in reverse. This hole reduces the pressure slightly and also relieves any cross leak oil. The hole also allows the band servo to retract quicker for a cleaner manual 1-2 shift
Old 04-12-2010, 08:43 AM
thanks I will try the hole and check valve body for warping I set the band with pry-bar to 3/8 the first time and did it by turns the last time
anyone know how to make a reverse shift pattern 727 valve body? the nitro man Transmission - Rearend 0 06-13-2009 12:18 PM
4l60E Slow Reverse jadejoky28 Transmission - Rearend 4 05-21-2009 11:41 AM
86 Dodge 4x4 727 tranny no reverse after loud metallic pop sound? mike 96 ws6 Transmission - Rearend 4 03-14-2006 12:43 PM
727 reverse shift/tremor problems Gen3_with_455 Transmission - Rearend 1 11-09-2003 01:47 AM
