727 slips from 2nd to 3rd - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2005, 05:52 PM
I have a rebuilt 727 all new pump everything except the valve body, it is slipping while shifting from 2nd to 3rd once its shifted there is no slipage while moving, and it seems to be worse when cold gets better once its warmed up,
could it be the valve body?...
Thanks gary
Old 08-20-2005, 01:16 PM
Crosley's Avatar
Wiki Edits: 1659
Thanks gary
clutch pack clearance in direct drum and the band adjustment are a critical area of the 727 for a clean 2-3 shift.
Is the throttle valve linkage set correctly?
Was there a shift improver kit installed in the v-body?
was the wavey snap ring re-used in the direct clutch drum?
What is the setting on the 2nd gear band?
Old 08-20-2005, 04:40 PM
I set the clearance to the manual specs on the clutches, i did reuse the wave snap ring, the band were tourqed to the manual specs inch pounds then backed off the # turns, don't rem off the top of head how many. there is no shift inprover kit installed..... the throttle valve linkage was set to specs. enless i am going about any of the ajustments wrong....
So far the sounds of what you are asking you might not think it could be the valve body?..
Thanks gary
Old 08-20-2005, 05:43 PM
airworld2's Avatar
sounds like shifts points are too low, try later shift points. normal 1-2 18 to 22 mph 2-3 shifts 30-35 depends on your foot. I set my bands with pan off but motor states 2nd band all the way in back off 3/4 turn.
Old 08-20-2005, 07:00 PM
I'll try the shift points and see what happens...
The bands in my manual say something like 70 in pounds not sure exactly i would have to look it up, then back off 2 1/2 turns....
th350 slips in 3rd 71ss Transmission - Rearend 9 11-08-2004 09:44 PM
TH350 not engaging in 2nd and 3rd NoEgoMan100 Transmission - Rearend 11 10-21-2004 05:35 PM
My 2nd Close Call - 3rd Time's HOPEFULLY Not A "Charm" nightrain_rod Hotrodders' Lounge 12 12-09-2003 07:11 AM
1st, 2nd, 3rd! No 4th gear Deadtemple Transmission - Rearend 6 10-15-2003 08:15 PM
'67 Mustang Trans 2nd & 3rd gears going. 67 302 Transmission - Rearend 0 02-09-2003 05:13 PM
