I'm replacing my A833OD with a 727 torqueflite. I built my own shifter and I'm using a shifter cable. The cable, a B&M, is threaded on one end and a loop on the other. My question is what is the best way to hook the the cable to the transmission? Would it be okay to bend the threaded end into a 90 and hook that into the shifter lever on the transmission using a locknut to secure it? If that will not work, what would be the alternative?
Thanks for the reply Cranky. I didn't know if bending the threaded end of the B&M cable would take out any slack I would have for adjustment. I was able to find a linkage kit from B&M for the 727. Guess I should have checked there before posting this question. I assumed being Summit and my aftermarket mopar vendors didn't have one, there was not one for the 727. But you know what they say about assuming......
Well thought I was on the right track. It seems the kit B&M sent me has the bracket facing the wrong direction and has my shifter shifting in a reverse pattern with low being towards the dash. The shifter cable connects below the pivot point on my shifter. I believe the kit is for a shifter that has the cable connecting above the pivot point.
I did some searching, looks like the B&M Unimatic shifter is built similar to mine. I'm going to give B&M a call today to see if they have another cable bracket kit for the 727.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
