727 torqueflite linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2009, 03:20 AM
Buy usa d job u savmaybyourown
Will it damage a torqueflite to run without the carb linkage?
I have my torqueflite in and I hooked up a B&M Ratchet but im wondering if I can manually shift the ratchet until I get a carb link? If any of you experienced guys with the 727 3 speed knowledge could help I would appreciate it. Thanks.
Old 09-02-2009, 09:53 AM
Last journal entry: 50 Ply wagon
The only way you can shift it manually is to have a manual valve body in the trans. You may do some damage to the trans not having the kickdown hooked to the trans and shifting it.
727 Torqueflite - throttle rod hook up Highway Transmission - Rearend 4 02-13-2009 05:09 PM
727 pushbutton linkage qool58 General Rodding Tech 2 12-10-2007 09:27 AM
727 torqueflite engine swap question qool58 General Rodding Tech 1 12-01-2007 09:10 PM
727 kick down linkage nasty33 Transmission - Rearend 1 04-25-2007 06:54 PM
'66 Chrysler 300 Torqueflite 727 tranny removal Bo_Jangles Transmission - Rearend 10 03-05-2002 07:43 AM
