727 Torqueflite Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2005, 12:52 AM
Quickhemi's Avatar
Last journal entry: Hemis at Big River Nationals
I have an A727 behind my early 331 Hemi and have rebuilt the trans and installed a TransGo kit.
Initial lockup of the trans was traced to having insufficient clearance in the rear clutch pack.
This has been since rectified and all seems well except for it going into stall on the converter when in park!!
Any help would be appreciated
Old 12-30-2005, 01:00 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Not quite sure what you mean..... can you describe what is happening? Is the rpm climbing, or the engine loading, ect.
Old 12-30-2005, 11:08 PM
Quickhemi's Avatar
Hi,
The engine loads as if trying to drive against the park brake sprag and the car torques up.
Regards,
Quickhemi
Old 12-31-2005, 08:22 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Hi,
Regards,
Quickhemi
DOES reverse works correctly or does it bind up / not want to move easily???
IF reverse is OK , you have a problem in the valve body or a cross leak in the pump stator area.
IF reverse binds up then the forward clutch is the problem area ....... incorrect clearance, burned up & stuck frictions, cross leak , valve body problem.
I wish I could be more specific. I'd pull the v-body and revisit the TransGo kit install very closely
Old 01-01-2006, 08:18 AM
Quickhemi's Avatar
re: 727 Torqueflite Problem
Thanks Crosley,
Reverse is fine.
I will drop the pan and check out the valve body.
I have another stock valve body that I may try to see if it works OK.
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Newest Transmission problem RObs71Nova Transmission - Rearend 4 01-30-2005 07:00 AM
Piston/valve interference problem jameskirk1 Engine 12 12-03-2004 04:14 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
'66 Chrysler 300 Torqueflite 727 tranny removal Bo_Jangles Transmission - Rearend 10 03-05-2002 07:43 AM
