Yes... It raises the line pressure of the trans in accordance to throttle opening. With it unhooked the trans thinks it is in park when you want to chirp second gear .
With the throttle wide open adjust the rod to where the detent arm on the trans is at full movement against it`s stop. Dan Hurst |
| Junkyard Motors.. | Zartan | Engine | 20 | 07-08-2011 07:52 AM |
| ?? Bore Sizes ?? | ss crazy | Engine | 2 | 10-03-2003 02:51 PM |
| Q-Jet Metering Rod Idea | Silver_Camaro | Engine | 6 | 09-16-2003 01:48 PM |
| Throttle cable swap... how does the pedal end hook up? | sizemoremk | Engine | 3 | 07-21-2003 01:54 PM |
| Proper throttle spring placement | willys36@aol.com | Engine | 1 | 11-13-2002 07:19 PM |
