Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 727 trans no forward gears
Old 11-18-2004, 04:26 PM
gorf24 gorf24 is offline
It has the proper seals, I replace every thing clutches seal bearings bushings, front pump gears, tourqe converter, its not a lockup unit, i did not replace the value body but cleaned it good befor replacing.
I have no forward gears at all no 1,2,3 manual shifting or not, it seems like a fluid presure problem to me but i hate to pull it out till i know were the problem is.
Are the ways to test the presure while running other then the coolant line.
Thanks
