Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 727 trans no forward gears
Old 11-19-2004, 05:20 PM
gorf24 gorf24 is offline
yes i replaced the piston seals and the spline was fine...
I started pulling it out today will be tearing it down to see what might be the problem, I am going to check the seal in the front cluches to see if that maybe got messed up, it seems to have good fluid presure and if the seal is broke the clutches won't engage, correct me if i an wrong...
