Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 727 trans no forward gears
Old 11-20-2004, 10:50 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
As stu points out the clutch drum you need to inspect..... it has the input shaft pressed into it
hope this helps
