Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 727 trans no forward gears
Old 11-21-2004, 07:32 AM
gorf24 gorf24 is offline
I did an air pressure test and the rear cluches are not moving in case... then i pulled the pump and fount and rear cluches, no i did a bench test still on rear cluch movement, i then disasembled the rear clutchs and did a presure test i get no air presure going to the rear cluch, i will get it sometimes but not most of the time the holes are not clogged its almost like the proper holes are not lined up i tryed it with the shim and without but the same result its a new front shaft, i just can't tell if all the holes line up after i lay the clutches onto the pump for testing.....
Thanks gary
