Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 727 trans no forward gears
Old 11-21-2004, 03:22 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
If you have a mismatch of the input shaft / drum design and the pump cover ( aka stator support) ..... it will not function correctly.
The clutch pack is fed differently with sealing rings in different locations
