We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 11-17-2004, 06:41 PM
gorf24 gorf24 is offline
727 trans no forward gears
I have a rebult 727 trans new clutches, plates, bushings, pump
forward/reverse bands, tourqe converter...
But i get no forward gears, only reverse.
Anyone have any sugestions as to want i shoud check or be looking for.?
Thanks
Old 11-17-2004, 06:48 PM
fixem all's Avatar
fixem all fixem all is offline
New Member
727 aka as tourqflite came with lockup and non lock up tourq converters and if mixed up will result in no drive condition
check valve body it can also be there too me and my buddy had trouble with one and ended up replacing it!
Old 11-18-2004, 04:02 AM
stu stu is offline
Did you assemble the forward clutch properly?
Did you install the correct sealing rings on the input shaft?
Will the transmission move forward in maual low?
Old 11-18-2004, 04:26 PM
It has the proper seals, I replace every thing clutches seal bearings bushings, front pump gears, tourqe converter, its not a lockup unit, i did not replace the value body but cleaned it good befor replacing.
I have no forward gears at all no 1,2,3 manual shifting or not, it seems like a fluid presure problem to me but i hate to pull it out till i know were the problem is.
Are the ways to test the presure while running other then the coolant line.
Thanks
Old 11-19-2004, 02:45 PM
stu stu is offline
Did you replace the piston seals?
Did you check the splines in the rear annulus gear?
Old 11-19-2004, 05:20 PM
yes i replaced the piston seals and the spline was fine...
I started pulling it out today will be tearing it down to see what might be the problem, I am going to check the seal in the front cluches to see if that maybe got messed up, it seems to have good fluid presure and if the seal is broke the clutches won't engage, correct me if i an wrong...
Old 11-19-2004, 07:15 PM
stu stu is offline
It isn't the front clutches at fault. They are direct and reverse.
It's the rear clutch pack. Those are the forward clutches.
Old 11-20-2004, 10:50 AM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 713
Cool
As stu points out the clutch drum you need to inspect..... it has the input shaft pressed into it
hope this helps
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Old 11-21-2004, 07:32 AM
I did an air pressure test and the rear cluches are not moving in case... then i pulled the pump and fount and rear cluches, no i did a bench test still on rear cluch movement, i then disasembled the rear clutchs and did a presure test i get no air presure going to the rear cluch, i will get it sometimes but not most of the time the holes are not clogged its almost like the proper holes are not lined up i tryed it with the shim and without but the same result its a new front shaft, i just can't tell if all the holes line up after i lay the clutches onto the pump for testing.....
Thanks gary
Old 11-21-2004, 07:39 AM
stu stu is offline
Do this.
Place the pump face down in a vice.
Don't tighten it too much, just enough to hold.
Install both drums.
Air check the system.
You should be able to apply the forward clutches by placing a finger over one hole in the input shaft and applying air pressure to the other.
You do have the metal sealing rings installed on the input shaft?
They are the correct size?
Old 11-21-2004, 08:50 AM
I tried that but no good, after taking a closer look at the input shaft I noticed there is no hole between the 2 metal seal rings, looking at the picture it appears to have a hole there but had to tell, if it indeed needs a hole can i drill it?... It's a new input shaft i took and had pressed in...
Old 11-21-2004, 09:48 AM
stu stu is offline
If there is no hole remove the shaft and install another one.
Old 11-21-2004, 09:53 AM
So are you saying i can't drill it, I have had the shaft for 6 months or more and will not be able to return it.... I looked in another trans book and indeed it showed the two shafts the pre 1978 had a hole and 78 and later had no hole mine is a 1977.... so i guess this might explane the problem...
Old 11-21-2004, 09:57 AM
stu stu is offline
It doesn't matter what year they are out of or from. It must have feed holes.
Old 11-21-2004, 03:22 PM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 713
If you have a mismatch of the input shaft / drum design and the pump cover ( aka stator support) ..... it will not function correctly.
The clutch pack is fed differently with sealing rings in different locations
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
