727 transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2005, 12:27 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I have a friend who has a '73 dart with the 727 transmission. Recently he replaced all the friction discs and steels, along with all the seals, bushings, front drum, and the stator. He says, " It now acts like it has a fully manual valve body in it. It no longer shifts automatically. The transmission stays in whatever gear you put it in."
Any suggestions? Governor pressure?
Old 11-22-2005, 06:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the gov would need to be stuck in the upshifted position for the trans to act like it is full manual shift unit.
I hope he matched up the replacement parts correctly. Specially the pump , stator & drum setup..... this could be the trouble
Old 11-23-2005, 12:54 PM
RodFather's Avatar
Thanks alot I will pass it along.
4t80e Cadillac Transmission Problems? mile-hightoyz Transmission - Rearend 8 05-12-2008 09:15 PM
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
4L60E transmission problems BICHN69 Engine 1 08-14-2004 11:23 PM
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 06:56 AM
Help!! Ford Windstar Transmission Problems NAIRB Transmission - Rearend 0 05-11-2004 08:25 PM
