You can use the nova brakes, but not the camaro after 70 with out making some modifications.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
If you are going to use the original drum brake spindles, you need to make a space approximately 0.600" thick to go onto the threaded boss on the spindle.
Or just swap the 73 spindles and all over on to the 70 front end.
(I think this boss is for the dust shield mounting bolt- but not sure. It's been a while.)
novajohnb. You have to mill off .610 of the top mount. not add to it.
To use the spindles off of the later camaros you have to use after market upper a frames, very expensive. but it will let you use the bigger brakes.
You both need to go to the knowledge base, there is lots of info there for this modification.
Troy
No problem. Just use the '73 spindles & everything that's attached to them. Use whichever steering arms (they connect the spindle to the tie rod) are shorter if you want faster steering. Don't forget the master cylinder/booster/rod & the proportioning valve & the plumbing. I'd use new hoses though. You may have to drill the back side of the A-frames for the brake hose clamp screws. The two cars are virtually identical underneath. The '73 rear end is stronger, & should have perches for multileaf springs.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
