73-80 chevy 1500 lowered, shocks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2011, 09:32 PM
Hi, My 75 c1500 is lowered about 4 1/2 inches and i am in need of some shocks for the rear, I know i can get lmc ones but was wondering if anyone has found some that will work without spending so much?
Old 05-31-2011, 08:09 AM
If you have not changed the shock mounts and if you have not C notched the truck then any factory replacment will work... may not be ideal... but it will work because the factory shock absorber is deisgned to go through the full range of suspension travel until the axle bottoms out on the facotry bumpstop.
Old 05-31-2011, 12:29 PM
The stock shocks wont fit cause they cant get small engough, I no longer have the factory bump stops. I flipped the axle over the springs.
1995 chevy 1500 SonnyFaust Transmission - Rearend 9 12-26-2008 11:17 PM
02 chevy 1500 4x4 v6 to v8 swap mike1975hd Introduce Yourself 2 10-15-2008 11:02 PM
Lowered 03 Chevy 1500 problems fordboy_460 Suspension - Brakes - Steering 4 05-10-2006 09:39 PM
My lowered 92 Chev 1500 rides too low. jpd37 Suspension - Brakes - Steering 3 07-15-2005 10:52 AM
Shocks for a lowered El Camino stinky jinx Suspension - Brakes - Steering 1 07-10-2005 06:50 AM
