Mopar "B" bodies don't have springs on the front suspension. They use torsion bars. If you're going from a small block to a big block then you'll probably want to swap them out for the heavier duty torsion bars. They'll handle the extra weight better. Out back you'll want to go with a set of super stock springs. Both the torsion bars and springs are available at Jegs. The springs go for about a hundred bucks and the torsion bars are around three hundred. You'll also want to make sure your differential has a pinion snubber. Mopar added those to big block performance cars to eliminate spring wrap.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
