73 B body suspension question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2012, 06:56 PM
ramman1500's Avatar
Last journal entry: work has been going slow but sure
ok all, i think i finally got the right plan for my 400 build . now i am curios about the entire suspension - i am going from a small block to a big block and i want to rebuild the suspension , using new springs and polyurathane bushings all the way around ..... is there a difference in the springs or where they the same ??????
Old 01-13-2012, 07:12 PM
Wiki Edits: 49
Mopar "B" bodies don't have springs on the front suspension. They use torsion bars. If you're going from a small block to a big block then you'll probably want to swap them out for the heavier duty torsion bars. They'll handle the extra weight better. Out back you'll want to go with a set of super stock springs. Both the torsion bars and springs are available at Jegs. The springs go for about a hundred bucks and the torsion bars are around three hundred. You'll also want to make sure your differential has a pinion snubber. Mopar added those to big block performance cars to eliminate spring wrap.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
g body suspension cbrock420 Suspension - Brakes - Steering 1 01-04-2012 06:15 AM
Air suspension in a g-body question inbredjedd Suspension - Brakes - Steering 3 10-16-2009 11:38 AM
GM B-Body Suspension Bull_81073 Suspension - Brakes - Steering 15 05-05-2009 01:40 PM
G body suspension airman_turtle Suspension - Brakes - Steering 2 08-31-2004 02:19 PM
3rd gen F-Body suspension KeithB123 Suspension - Brakes - Steering 5 01-09-2004 09:56 PM
