73 Chyenne Pickup windshield
i bought the truck with a broken windshield.. once i found a windshield. i ordered a gasket to put it in with.. now the gasket i got was designed not to use the chrome bead locking strip.. but i have no idea how this new gasket goes on the windshield.. it came with no instructions?? anyone give me a hand with this problem?
2 (two)three is good too
person job 1st method; you will need string(strong nylon 1/4')soft silicon spray masking tape suction cups are nice to have put gasket around glass put glass on outside of cab put string around gasket 360* put the fattest part in (bottom) one guy inside one out pull string around glass slowly and carefully using the spray if it starts to bind up pull string from inside without side guy holding it in place and putting slight pressure on it try to pull the string one side @ a time a little 1 side little the other back and forth back and forth @ a 90* to the glass working the gasket into/onto the lip and it should pop in eventually might not go in the first few times 2nd method call a professional auto glass installer they break it they buy it you make sure of that PS windshields are totally different than the rest of the glass it will pop and run a crack in a new york minuet without warning !!! THIS IS THE ONLY WARNING YOU WILL RECEIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! been there got the t shirt and the broken glass i think thats all i know about that other than return the old one and get the good ones either the rubber insert or the crome insert the rubber one there is a special too for installing and removing good luck sr66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
| 73 Jeep J4000 FullSize Pickup | radium | Body - Exterior | 0 | 11-01-2003 03:14 AM |
| Windshield Wipers for 1954 Chevy Pickup? | horvath | Body - Exterior | 8 | 09-11-2003 09:25 PM |
| Windshield Frame for '54 Chevy Pickup | horvath | Body - Exterior | 5 | 03-31-2003 05:07 PM |
| 73 Pontiac Firebird Fuel Pickup Sending Unit | Rad Ray | Engine | 3 | 02-05-2003 08:39 AM |
