'73 Cub Cadet 100 has no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2011, 07:30 AM
Wiki Edits: 31
My grandfather has a 1973 Cub Cadet 100 that has had an engine swap with a 12hp Kohler, which replaced the blown 10hp Kohler. For the most part it usually runs pretty good. but one day recently, he shut it off, went inside for a few mins and it wouldn't restart..
I got a chance to check it out, and the points are switching ( and new last year ), I can see the voltage switching at the coil, but it has no spark.. The Condensor is what I think the culprit is, but the coil and plug/ coil wire also appear original. What should I change out? I ohmed out the coil, but I have no idea what it should be
Old 06-29-2011, 03:14 PM
willowbilly3's Avatar
Last journal entry: Body mods
If it's pulsing the coil and it has no spark it is probably in the secondary, which means coil, coil wire or spark plug. I,m not sure on ohming the coil, my guess is about 3 ohms on the primary side and 6000-12000 on the secondary side. If you don't get it figured out, let me know, I have an old cub 100 I could go ohm the coil.
Here's a real good forum for garden tractors
http://www.mytractorforum.com/forumdisplay.php?f=30
Old 06-30-2011, 02:23 PM
Wiki Edits: 31
Got it running. Coil didn't seem right and was getting extremely hot. ohmed it again and it was producing a lot more resistance than it was @ 16 ohms. got a new 1 at the parts store and it ohmed out to 8 ohms, so I replaced it, and it had spark
Any Cub Cadet Experts here? Joelk General Rodding Tech 0 10-24-2010 07:27 PM
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 06:14 AM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 09:30 AM
spark plug getting little spark 72 chevy elcamino Electrical 1 10-19-2003 05:54 PM
spark plug spark rustyrazer Hotrodders' Lounge 1 12-24-2002 04:57 AM
