73 duster engine swap q's - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2002, 09:21 AM
Post 73 duster engine swap q's
is the transmission on my 225 slant six going to bolt up to a 318, and im going to do a full bottom end rebuild, with edelbrock air gap intake and try to fit in a mopar purple cam, will the tranny and rearend holdup, its a 904 with 3 on the tree and the rearend is a 8 1/4, any help is apreciated thanks...
Old 10-13-2002, 12:51 PM
roys63's Avatar
Post
NOPE the starter is in the wrong spot
Old 10-13-2002, 01:48 PM
Post
thats what i was thinking... well thanks. um so i need to get a small block 727 trans, then if im going in this far i should just cut down a ford 9in so the drivetrain would be bulletproof right...
Old 10-13-2002, 03:21 PM
roys63's Avatar
Post
I would run the rear till you break it and spend your money elsewhere
