73 elcamino - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 08:07 AM
73 elcamino
when i put my car in drive it will move about 10 feet before it bogs out any help with figuering out what is the problem
Old 02-22-2006, 08:45 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
blocked exhaust?
Old 02-22-2006, 08:58 AM
73`elky
the exaust is good fairly new little rust u can really feel the exhuast blow out the pipes thats why i cant figure out whats the problem
Old 02-22-2006, 03:31 PM
73oldsman's Avatar
More info may help. What size engine is it and what carb is on it? Does it bog down and die? Does it bog down, then run o.k. after that? Have you done any work on it recently, and how was it running before you worked on it? Does it backfire while bogging down or make other noises? Do you smell fuel when it bogs down? Changed the fuel filter lately or messed with the choke? Man, I could go on and on. We need more info to help you friend.
Old 02-23-2006, 07:47 AM
its a stock 350 with a 2barrel carb after it bogs down it dies but it will start up again and idle its just when u put it in drive or reverse it goes about 10 - 15 feet and dies. no i havent messed with the choke or anything else i just bought the car from my friends impound lot and i am trying to fix it up it has new interior and new paint job it just needs some minor engine work
Old 02-23-2006, 08:52 AM
Infomaniac's Avatar
Check fuel filter fuel pump (pressure) and take the gas cap off and see if it is venting.
Old 02-23-2006, 11:08 AM
we checked the fuel pressure and filter is new also checked the fuel line to see if it is sending fuel to the carb it all seems ok
Old 02-23-2006, 11:20 AM
johnsongrass1's Avatar
Race it, Don't rice it!
It sure sounds like a fuel system problem. Have you tried a different carb?
Old 02-23-2006, 03:50 PM
73oldsman's Avatar
What was the fuel pressure? Is the accelerator pump in the carb squirting fuel in the carb when you actuate it?. If so, is the choke operating properly and opening up after warmup? Just some more ideas.
Old 02-23-2006, 05:45 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Is this a 2GV carb? ....
Check the primary pump for shot..
2 GV' are picky in colder weather..
Doc
72 nova door panels to 73 doors... fireforsin Interior 2 02-18-2008 04:45 AM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 09:57 AM
73 Dart Sport parts interchange? dadeeoo Electrical 0 04-12-2004 11:39 AM
Big block for my 73 Nova Hatchback? 73 Nova Guy Hotrodders' Lounge 7 02-26-2003 10:40 AM
