73 firebird rear decode help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2011, 11:08 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
Hey everyone I need some help figuring out what kind of rear end my moms firebird has.
Here are the codes I have found...
GZC 178 1
N 1235542 B
I'd like to know if it's a 8.2 or 8.5 is it a BOP or a standard GM rear?
Old 11-28-2011, 02:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
GZ should be a 2.73 Rear Gear (Open).
N 1235542 B shows it being a 8.5 but don't hold me to that measure the rear cover and see what size it is should be like 11.250 for the 8.5.
Cole
Old 11-29-2011, 10:53 AM
Last wiki edit: Mounting an electric fuel pump Last photo:
just wondering but what would the 8.2 measure out to be and where do you mesure?
Old 11-29-2011, 03:23 PM
SSedan64's Avatar
10-Bolt Rear ID:
Name:	10 Bolt Rear ID.jpg
Old 12-01-2011, 03:38 PM
Originally Posted by SSedan64
10-Bolt Rear ID:
Well according to the measurement the pic and the codes it is an 8.5 Chevy rear thank you very much
Old 12-01-2011, 10:32 PM
SSedan64's Avatar
The 8.5" 10-Bolt is a strong Rear.
Lots of upgrades available, 30-Spline Axles, Posi's, Soilid Pinion Spacer, Diff Girdle Cover.
Old 12-02-2011, 09:25 PM
I'm not going to build up this rear much at all just a refresher then a build. This is in a cruiser for my mom. Basically just going to find a good junk yard posi to replace the peg leg new axles and new gear set
Old 12-03-2011, 06:56 AM
SSedan64's Avatar
Stay away from the Gov-Lock Diff, An Auburn or Eaton Posi will work well.
Gov-Lock Pics >> http://www.google.com/search?tbm=isc...0l0l0l0l0ll0l0
Old 12-03-2011, 06:26 PM
funny u should say that bout the gov loc. i have on in my 425 powered c10. last week i shreaded a thirty spline axle spinning on a icy hill. was doing around 30 when i started to spin, i let off and when th wheel speed got below the gov speed, it locked and snapped the axle on the dry. nothing wrong with the locker tho and i love it. works great and i do recomend them for responcible drivers
Old 12-07-2011, 04:39 PM
What I have planned for the rear is 3.08s decent axles undecided on brand and I am leaning towards 30 spline. and either a junk yard posi if I can find one or an eaton.
decode rear end tag ford 9inch cswinc1028 Transmission - Rearend 1 05-13-2008 07:02 PM
1980 Camaro Rear end decode help rwruther Transmission - Rearend 0 09-17-2007 02:46 PM
Rear Axle decode Scorpion8686 Transmission - Rearend 1 04-01-2005 07:09 AM
Ford Rear tag decode 87442lover Transmission - Rearend 1 05-14-2004 10:15 AM
Decode rear end #'s, HELP Rodie40 Transmission - Rearend 1 07-01-2003 07:58 PM
