73 Impala Ignition Switch Cylinder Jammed - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2011, 11:06 PM
jonathanks's Avatar
New Member
Hey all!
1973 Impala interior all stock, not tilt column.
Lock cylinder totally jammed, had to drop column and pull switch to start car when i needed to move it. I have the housing with the lock cylinder sitting on my desk, so it is accessible as it can get. I can't get it to line up properly in the 'on' position to get it out, the tumbler is just too fried. The assembly doesn't seem to turn together. I suppose I could dill it out, but want to be less destructive if possible.
Am I donw to drilling or a locksmith, or is ther another trick? Then I just have to get the right cylinder....
Old 03-10-2011, 03:01 AM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
Dont know what all youve tried yet but if you can get the key in try sprayin it with some lube and runnin it in and out and wiggle it around inside there. Worked for me before.
Old 03-10-2011, 03:44 AM
EOD Guy's Avatar
Locksmith or drill it...... you can buy replacements on Ebay pretty cheap.
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
Ignition Switch?? or what ponybuster Electrical 13 12-29-2003 09:17 PM
Ignition Switch dollybud General Rodding Tech 2 10-30-2003 07:20 AM
Ignition Switch ?? ponybuster Engine 8 10-11-2003 06:58 PM
Emergency - 67 Impala Ignition Switch (dash) doctormidnight Electrical 2 12-15-2002 04:29 PM
