Start a wiki article on any hotrodding subject:
Then, others help to build it.
Read and write hotrodding articles in the Crankshaft Coalition Wiki.
See 150+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 10-29-2005, 05:11 PM
AngliaBob's Avatar
AngliaBob AngliaBob is offline
It just takes time and money
73 Jeep Commando no start
I picked up a client car the other day, drove 4 miles and the alt light and burning insulation smell got to me at the same time. I pulled over, opened the hood, and saw the insulation on the alt wire was non-existent. So, I coiled it up, and drove the remaining 4 miles. I parked it and later, restarted it to get to my garage. I replaced the alt wire, rerouting it away from the block. Tried to start it today and I get one click from the Ford type starter relay (in the run position) and no starter crank. All electrical accessories (lights,radio,turn signals) work. If I jump the battery directly to the starter I have cranking. I don't know where to go from here. Any help would be appreciated.
Thanks,
Bob
Old 10-29-2005, 05:34 PM
docvette's Avatar
docvette docvette is offline
docvette's barnstarLast wiki edit: Rebuild an Alternator
Wiki Edits: 12
Doc here,
Check the start side of the ignition switch..
Put a meter, or light, or (If working by yourself) jump a wire to the horn (you can hear it when it energizes) on the "S" line on the solenoid..you SHOULD have 12 volts in the "Start" position, and it should drop out when you return the key to run..If not, your short may have damaged the switch..
Also be sure to check ALL the fuse links..your Alternator SHOULD have had one..If not I'd put one on that line...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-29-2005, 08:25 PM
AngliaBob's Avatar
Doc,
Thanks for the reply....that's were I was going next....but....
I took my jumper cables and hooked up to the starter lug and hit the batt pos..It kicked...After that I can turn the key and it's reality again.
Thanks
Bob
Old 10-30-2005, 01:06 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Fine job....thanks for posting back and letting us know..
Sounds like you may have a sticking relay or burned contacts..if it ever happens again..
Happy Motoring!
Doc
Innovations
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "73 Jeep Commando no start"
454 new timing chain and gear, will not start Old and worn out Engine 6 12-04-2003 08:15 AM
Help! engine won't start Jeep'n Engine 9 11-13-2003 07:39 AM
Hard to start when hot GMC big block 454 b5three Electrical 8 06-05-2003 12:48 PM
Help Wifes Jimmy Won't Start Jumboset Electrical 3 05-06-2003 02:20 PM
'73 Monte Carlo died Seon Engine 4 10-31-2002 06:42 PM
