We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-20-2002, 05:06 PM
Seon's Avatar
Seon Seon is offline
Post '73 Monte Carlo died
I posted in the electrical forum that my son's '73 Monty backed fired and died at 65 mph, then wouldn't start. It ended up that the timing chain gear's nylon gave way. My son replaced the timing chain and put everything back together, then tried starting it..but wouldn't start. It wanted to start but just sputtered. I checked the compressions and appears that there's a couple of cylinder with 30 lbs or so compression. This tells me that it bent some of valves. With 118K miles on the engine, I adviced my son that it would be cheaper to yank the engine and tranny out and get a new crate engine from the dealer and replace the 350 turbo with a rebuilt 700r4. I guess the old addge is true,..."when it rains, it pours".
Old 10-20-2002, 05:49 PM
slider in wa's Avatar
slider in wa slider in wa is offline
Slider in Wa.
Post
Some times the Dad knows best!!!!
Slider in Wa.
Old 10-31-2002, 04:15 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
1BAD80's barnstar
Wiki editor
Last wiki edit: How to adjust valves
Wiki Edits: 2
Post
I agree with Daddy.Heres GM site for parts and crate motors.LOL
www.spoperformanceparts.com
Luv the smell of NITRO in the morning.
Old 10-31-2002, 07:28 PM
helrazr3's Avatar
helrazr3 helrazr3 is offline
im on a highway to hell
Post
well if cost is not an option go ahead and pull the motor and tranny i dont know if you were waiting for an excuse to update the drive train but you dont HAVE to pull the tranny right now. before i called up to order my crate motor i would check with a few machine shops and price a rebuild of what you have. if your block is good you could get a good price on a rebuild. good luck
Old 10-31-2002, 07:42 PM
slider slider is offline
Post
I don't think a low compression 350 is gonna do that. I've lost several timing chains on those and never had a valve hit. Before yanking the engine, pull the valve covers and take a look at the offending cylinders hardware. A stuck valve is going to show up visually. Besides if it is an intake shouldn't it should backfire? Or an open exhaust 'pop'?
It sounds like he's a tooth off on the gears. But then I've been wrong lots.......
[ October 31, 2002: Message edited by: slider ]</p>
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
