73 nova 700r4 problem?
im in the process of restoring my nova. it has a new motor (350 bored .60 over) and a 700r4 that just came out of the shop. the engine strains when i put it in gear...like it wants to die. sometimes it will. now im pretty sure its not the tranny... because the th350 that was in there a week ago did the same thing. its possible the motor isn't tuned all the way it could probably use some more advancing. but even so why should the engine be strained by me just putting it in gear? the stall is somewhere around the 2000-2500 range. everything in the drivetrain is new and the engine pulls 13'' vaccuum.
Specs:
350 4 bolt main bored .060 over
Comp cams XE268
10.5:1 compression
Dart Platinum 200cc
Edelbrock RPM Airgap manifold
Barry Grant Speed Demon 650.
Pertronix FlameThrower II Ignition
Flowtech Longtube headers /w 2.5'' exhaust.
700r4 tranny
Beast Sunshell
Z-Pak, Corvette servos, stage II shift kit.
Bowtie Overdrives custom crossmember and TV cable setup.
